ArKos Opublikowano 7 Marca 2010 Udostępnij Opublikowano 7 Marca 2010 Untitled Document F-16 F16CR F16WR 1. 3,417 / 3,545* 3,417 / 3,545* 2. 2,158 1,952 3. 1,480 1,276 4. 1,121 0,892 5. 0,892 0,707 R 3,333 / 3,167** 3,333 / 3,167** Sprzęgło mechaniczne mechaniczne Zmiana biegów Lewarek mechaniczny Lewarek mechaniczny Zastosowanie: Model Kod silnika Kod skrzyni Alphacode Przełożenie główne Ascona C 20NE, 20SEH, C20NE F16CR CX, FQ 3,55 20NE, C20NE, C20NEF - J1118125 F16WR CR 3,55 20NE, C20NE, C20NEF J1118126 - F16WR FJ 3,55 E18NV, S18NV - J1145440 F16CR EE 3,72 E18NV, S18NV J1145441 - F16CR FR 3,72 18SE, E18NV, S18NV F16WR EA, FK 3,72 16SH, S16SH, 18E, 18SE, 16DA H1001772 - H6000000 - F16WR BR 3,72 16SH, S16SH, 18E, 18SE, 16D, 16DA - H1001771 - H6000000 F16WR AT, AV, ZY 3,74 16SH, S16SH, 18E F16CR ZT, BT 3,94 16SH, S16SH, 18SE F16CR EF 3,94 16SH, S16SH F16WR EB, FL 3,94 18E, 18SE, E18NV, S18E, S18NV, 16D, 16DA H1001772 - H6000000 - F16WR EB, FL 3,94 16NV, 16SH, A16NV, S16SH, 18E, 18SE, C18NE, E18NV, S18E, S18NV, 16D, 16DA F16WR AS, ZN, BN 3,94 16D F16WR AR 3,94 16NV, 16SH, A16NV, S16SH, 16D, 16DA F16WR BQ, CU 4,19 Astra F C18XE, C20NE F16CR NL 3,55 C20NE F16WR ND, AE 3,55 C18NZ F16CR FR 3,72 C18NZ, C20NE, 17DT F16WR UG, NE 3,72 F16WR AH 3,74 C18NZ F16WR NG 4,19 Calibra C20NE F16CR FQ, NL 3,55 F16CR NM 3,72 Kadett D 16SH, 18E, 16D F16WR AV, ZY, BR 3,74 18E, 16D F16WR AS, ZV, BN 3,94 Kadett E 20NE, 20SEH, 20SER, C20NE F16CR CX, NL 3,55 20NE, C20NE F16WR ND 3,55 F16CR AD 3,57 F16WR AE 3,57 18E, 18SE, C18NE, C18NT, C18NZ, E18NV, S18E, S18NV F16CR BS, EE, ZS, NM 3,72 18E, 18SE, C18NE, C18NT, C18NZ, E18NV, S18E, S18NV, 15DTR, 16D, 16DA, 17D, 17DT F16WR BR, EA, NE 3,72 C18NZ F16CR AF 3,74 18E, C18NE, C18NT, 16D F16WR ZY 3,74 18E, 18SE, C18NE, C18NT, C18NZ, E18NV, S18E, S18NV, 15DTR, 16D, 16DA, 17D, 17DT F16WR AH 3,74 16SH, A16SH, S16SH, 18E, 18SE, C18NE, C18NT F16CR BT, ZT 3,94 16SH, A16SH, S16SH, 18SE, 16DA F16WR EB, NF 3,94 16SH, A16SH, S16SH, 18E, C18NE, C18NT F16WR ZV, BN 3,94 16SH, A16SH, S16SH, 16D, 16DA F16WR BG, CU, FM, NG 4,19 Vectra A 20NE, C20NE, 20SEH F16CR NL, AD 3,55 20NE, C20NE, C20NEF, 20SEH F16WR ND 3,55 18SV, E18NVR, 20NE, C20NE F16CR NM 3,72 18SV, E18NVR, 17D, 17DR, 17DT F16WR NE 3,72 18SV, C18NZ, E18NVR F16CR NN 3,94 18SV, C18NZ, E18NVR, 20NE, C20NE, 17DT F16WR NF 3,94 F-17 F17(+)CR (MTA) F17(+)WR (MTA) F17WR.V1 F17+ER MTA 1. 3,727 3,727 3,727 3,727 2. 2,136 1,957 1,957 2,136 3. 1,414 1,303 1,303 1,323 4. 1,121 0,946 0,853 0,892 5. 0,890 0,761 0,674 0,642 R 3,308 3,308 3,308 3,308 Sprzęgło hydrauliczne; Agila, Astra F, Corsa B, Tigra A mechaniczne; MTA automatyczne hydrauliczne; Agila, Astra F, Corsa B, Tigra A mechaniczne; MTA automatyczne hydrauliczne automatyczne Zmiana biegów Lewarek mechaniczny, Meriva, Signum, Vectra C, Zafira B Lewarek z linkami MTA Pozycjoner Lewarek mechaniczny, Agila, Meriva, Signum, Vectra C Lewarek z linkami MTA Pozycjoner Lewarek mechaniczny Pozycjoner Waga ca. 33 kg Zastosowanie: Model Kod silnika Kod skrzyni Alphacode Przełożenie główne Agila Z13DT F17WR DZ 3,55 Astra F X16XEL F17CR MJ, NZ 3,55 16NZR, C16NZ, X16SZ, X16SZR F17CR MH 3,74 14SE, C14SE, X14XE F17CR MG 3,94 X17DTL F17WR TT, FN 3,94 Astra G Y17DT, Z17DTL F17WR DK 3,55 F17+WR LD 3,55 Y17DT Eco, Z17DTL Eco F17WR.V1 CJ 3,55 F17+WR.V1 LC 3,55 C16SEL F17CR UT 3,74 C16SEL, X16XEL, Z16XE, Z16YNG, X18XE1 F17CR CN, CT, DD, AN, MW, LF 3,74 C16SEL, Z16XE, Z16YNG F17+CR LF 3,74 X18XE1, Z18XE F17CR DD, AN, MW 3,74 Z18XEL F17CR AN 3,74 X17DTL F17WR HB 3,74 Z18XE F17CR CM 4,19 F17+CR LE 4,19 Astra H Z17DTL F17+WR WF, NG 3,74 Z16XEP (L48) F17+CR FL, DD 3,94 Z16XEP F17+CR QC 3,94 Z18XE - 52999999 - 55999999 - 58999999 F17+CR WE 3,94 Z18XE, Z18XER 62000001 - 65000001 - 68000001 - F17+CR QC 3,94 Z16XEP - 52999999 - 55999999 - 58999999 F17+WR MTA EU 3,94 Z16XEP 62000001 - 65000001 - 68000001 - F17+WR MTA K1 3,94 Corsa B, Tigra A C14SEL, X14XE, C16SEL, X16XE F17CR MK, XE 3,74 Combo C Z13DT F17+WR DY 3,55 Y17DT F17WR ZK, BR 3,74 F17+WR EE 3,74 Z16SE F17+WR AY 3,94 Z13DT, Z13DTJ F17+WR AX 3,94 Z13DTJ F17+WR MTA QX 3,94 Z16YNG F17+WR XC - 53999999 4,19 F17+WR NM 63000001 - 4,19 Corsa C Z13DT F17+WR DY 3,55 F17+WR MTA EP - 44999999 - 46999999 3,55 F17+WR MTA CM 54000001 - 56000001 - 3,55 Y17DT F17WR ZU, BP 3,55 F17+WR ED 3,55 Z18XE F17CR ZX, BS, CT 3,74 F17+CR LF- 54999999 - 56999999 3,74 F17+WR MTA QB 64000001 - 66000001 - 3,55 Z13DT F17+WR AX 3,94 Meriva Z16XE, Z18XE - 54999999 F17+CR KA 3,94 Z16XE, Z18XE 64000001 - F17+CR DF 3,94 Z16XEP F17+CR DF 3,94 Z16XE, Z18XE, Y17DT F17+WR KA 3,94 Z16XE, Z18XE, Y17DT - 54999999 F17+WR KA 3,94 Z16XE, Z16XEP, Z18XE, Y17DT 64000001 - F17+WR NJ 3,94 Z13DT F17+WR AX, AY 3,94 Z13DT, Z13DTJ F17+WR AY 3,94 Z16XE - 44999999 F17+WR MTA ER 3,94 Z16XE 54000001 - F17+WR MTA QM, K2 3,94 Z18XE - 44999999 F17+WR MTA ES 3,94 Z16XE 54000001 - F17+WR MTA QQ, K3 3,94 Z16XEP F17+ER MTA FT 4,19 Signum Z18XER F17+CR ZX 3,74 Z18XE - 51999999 F17+CR UB 3,94 Z18XE 61000001 - F17+CR ZW 3,94 Z18XER F17+WR MTA FQ 4,19 Tigra B Z13DT F17+WR DY 3,55 Z18XE F17+CR LF 3,74 Vectra B X18XE1, Z18XE, Z18XEL F17CR CS, DC, AN, CT 3,74 X16XEL, Y16XE, Z16XE F17CR CX, CJ, QN, CS 3,94 X18XE1, Z18XE, Z18XEL F17WR DA, AL, CL 3,94 X16XEL, Y16XE, Z16XE F17WR CR, AM, CM 4,19 Vectra C Z18XE, Z18XEL F17CR BW 3,74 Z18XE, Z18XEL - 51999999/- 58999999 F17+CR UC 3,74 Z18XE, Z18XEL, Z18XER 61000001 - F17+CR ZX 3,74 Z16XE F17CR BU 3,94 F17+CR UB, ZW 3,94 Z16XEP, Z18XE F17+CR ZW 3,94 Z18XE, Z18XEL F17WR BT 3,94 F17+WR UA 3,94 Z18XER F17+CR ZW 3,94 Z18XE, Z18XEL F17WR BT 3,94 Z18XE, Z18XEL F17+WR UA, ZU 3,94 Z18XER F17+WR L6 4,19 Z18XER F17+WR MTA FQ 3,94 Vectra C Caravan Z18XE F17+CR UB 3,94 Zafira A C16SEL, X16XEL, Z16XE, Z16YNG, X18XE1 F17CR QP, DH, AP, CR 4,19 C16SEL, Z16XE, Z16YNG F17+CR LG 4,19 X18XE1, Z18XE F17WR AM 4,19 Z18XE F17+WR LE 4,19 Zafira B Z18XER - 52999999 F17+CR UW 3,94 Z18XER 62000001 - F17+CR NE 3,94 Z16XEP F17+CR WT, ZY 4,19 Z16YNG F17+CR ZY 4,19 Z18XER F17+ER MTA FU 4,19 F-18 F18(+)CR F18(+)WR 1. 3,583 3,583 2. 2,143 1,870 3. 1,481 1,226 4. 1,121 0,919 5. 0,892 0,744* R 3,333 3,333 Sprzęgło mechaniczne; Astra G, Vectra B hydrauliczne mechaniczne; Astra G, Vectra B hydrauliczne Zmiana biegów Lewarek mechaniczny Lewarek mechaniczny max. Przenoszony moment obrotowy F18: 190 Nm, F18+: 205 Nm Waga ca. 36,3 kg Zastosowanie: Model Kod silnika Kod skrzyni Przełożenie główne Alphacode Astra F C20XE, X20XEV F18CR 3,45 MP, QK C20XE F18+CR 3,45 AB C18XE, C18XEL, X18XE, C20NE F18CR 3,57 AD, MQ C18XE, X18XE, C20NE, 17DT, X17DT F18WR 3,57 AE X20XEV F18WR 3,57 QJ, MW, AG C18NZ, C18XE, C18XEL, X18XE, C20NE, X20XEV, 17DT, X17DT F18WR 3,74 AH, MW Astra G X20XEV F18CR 3,74 UU X20DTL F18+WR 3,74 UN X20XEV F18WR 3,94 RZ Calibra C20NE, X20XEV F18CR 3,57 AD, MQ, EH, QD C20XE F18+CR 3,57 AC C20NE F18CR 3,74 AF Calibra 4x4 C20NE, C20XE, X20XEV F18+CR 3,74 AJ Vectra A 20NE, C20NE F18CR 3,57 AD, MQ X20XEV F18CR 3,57 EH C20XE F18+CR 3,57 AC 20NE, C20NE F18WR 3,57 AE 18SV, 20NE, C20NE F18CR 3,74 AF 18SV, C18NZ, 17DT F18WR 3,74 AH X20XEV F18WR 3,74 EJ 18SV, C18NZ F18CR 3,94 AK 18SV, C18NZ, 20NE, C20NE, 17DT F18WR 3,94 AA Vectra A 4x4 C20NE F18+CR 3,74 AJ Vectra B X20XEV F18CR 3,57 GF X20DTH, X20DTL F18+WR 3,57 GP X18XE F18CR 3,74 GG, UU X17DT F18WR 3,74 GR X20DTH, X20DTL F18+WR 3,74 GQ, UN X20XEV F18CR 3,94 GH X18XE, X20XEV F18WR 3,94 GS F-20 F20CR 1. 3,545 2. 2,158 3. 1,478 4. 1,129 5. 0,886 R 3,330 Sprzęgło mechaniczne Zmiana biegów Lewarek mechaniczny Zastosowanie: Model Kod silnika Alphacode Przełożenie główne Astra F C20XE WC, UM 3,42 Calibra C20XE FT, WD, UY, AR 3,55 Calibra 4x4 C20NE UZ 3,72 C20XE QM, WG 3,72 Kadett E 20XEJ, C20XE WC 3,42 FT, WD 3,55 AC 3,57 Vectra A 20XEJ, C20XE UY, AR 3,55 Vectra A 4x4 E18NVR, 20SEH, C20NE, C20XE UZ 3,72 F-23 F23WR F23SR F23SRT 1. 3,577 3,577 3,577 2. 1,887 2,022 2,022 3. 1,192 1,348 1,348 4. 0,848 0,977 0,977 5. 0,686 0,809 0,790 R 3,308 3,308 3,308 Sprzęgło hydrauliczne Zmiana biegów Lewarek z linkami Waga ca. 42,8 kg Zastosowanie: Model Kod silnika Kod skrzyni Przełożenie główne Alphacode Astra G Z20LET F23SRT 3,63 TR, AF Y20DTH F23WR 3,63 SB, AG, AB X20XEV F23SR 3,74 SH X20DTL F23WR 3,84 SA X20XER F23SR 3,95 TS X20XEV F23SR 3,95 SC Z22SE F23SR 3,95 SF, AH Astra H Z17DTH F23WR 3,95 QJ Corsa C Z17DTH F23WR 3,63 QF Combo C Z17DTH F23WR 3,84 QG Meriva Z17DTH F23WR 3,84 QG Signum Y20DTH F23WR 3,74 XU Z22YH F23SR 4,17 XY Speedster Z20LET F23SRT 3,63 AF Z22SE F23SR 3,95 TN Vectra B X20XEV F23SR 3,74 SR X20DTH, Y20DTH F23WR 3,74 SP X25XE, Y26SE F23SR 3,84 SK X20DTH, X20DTL, Y20DTH F23WR 3,84 SL X20XEV F23SR 3,95 SS Z22SE F23SR 3,95 ST X20DTL F23WR 3,95 SM X20XEV F23SR 4,17 SQ Vectra C Y20DTH F23WR 3,74 XU Z22SE, Z22YH F23SR 3,95 XX Z22YH F23SR 4,17 XY Zafira A Z20LET F23SRT 3,95 DZ Z22SE F23SR 4,17 SG X20DTL, Y20DTH F23WR 4,17 SJ, AK, AJ F-25 F25 oprócz Sintry 1. 3,38 2. 1,76 3. 1,12 4. 0,89 5. 0,77 R 3,17 Sprzęgło mechaniczne; Vectra B hydrauliczne Zmiana biegów Lewarek mechaniczny Zastosowanie: Model Kod silnika Przełożenie główne Alphacode/Numer części Calibra C25XE, X25XE 3,82 WT, QQ Vectra A C25XE 3,82 WT Vectra B X25XE 4,05 RC F25 Sintra 1. 3,67 2. 1,76 (FNr. - WD999999) 1,88 (FNr. XD000001 -) 3. 1,18 4. 0,89 5. 0,70 (FNr. - WD999999) 0,77 (FNr. XD000001 -) R 3,43 Sprzęgło hydrauliczne Zmiana biegów Lewarek mechaniczny Zastosowanie: Model Kod silnika Przełożenie główne Alphacode/Numer części Sintra X22XE FNr. - WD999999 4,05 DLJ 12556056 X22XE FNr. XD000001 - MD3 12560480 F-28 F28 1. 3,57 2. 2,16 3. 1,45 4. 1,10 5. 0,89 6. 0,74 R 3,32 Sprzęgło mechaniczne Zmiana biegów Lewarek mechaniczny Zastosowanie: Model Kod silnika Przełożenie główne Alphacode Numer części Calibra 4x4, Vectra A 4x4 C20LET 3,72 GZ 90465166 LZ 90423279 F-35 F35WR typ 1 F35WR typ 2 F35WR typ 3 F35WR typ 4 1. 3,38 3,58 3,67 2. 1,76 1,88 1,88 3. 1,12 1,18 1,18 4. 0,89 0,89 0,89 5. 0,70 0,66 0,66 R 3,17 3,43 3,43 Sprzęgło hydrauliczne Zmiana biegów W tabeli poniżej Model Kod silnika typ Przełożenie główne Alphacode/Kod części Zmiana biegów Astra G Y22DTR 2 3,61 UU Lewarek mechaniczny Signum, Vectra C Y22DTR 2 3,61 GU Lewarek z linkami Z32SE 1 4,05 GW Sintra X22DTH 4 4,05 12551393 Lewarek mechaniczny Vectra B Y22DTR 1 3,61 LN Lewarek mechaniczny Zafira A Y22DTR 3 3,82 UM Lewarek mechaniczny F-40 F40CR F40WR F40WR (Y30DT) 1. 3,769 3,917 3,769 2. 2,040 2,040 2,040 3. 1,365 1,321 1,321 4. 1,048 0,954 0,954 5. 0,846 0,755 0,755 6. 0,707 0,623 0,623 R 3,538 3,750 3,538 Sprzęgło hydrauliczne Zmiana biegów Lewarek z linkami Zastosowanie: Model Kod silnika Kod skrzyni Przełożenie główne Alphacode Insignia A20DTH ecoFlex F40WR 3,09 6Y A20DTH F40WR 3,55 R8 A20NHT F40CR 3,76 Q7 A20NHT 4x4 F40CR 3,76 R1 A28NET F40CR 3,76 R2 Signum, Vectra C Z19DT F40WR 3,35 WL, E9 Z30DT F40WR 3,35 CX Z28NEL, Z28NET F40CR 3,55 CW Z19DTH - 48999999 - 61999999 F40WR 3,55 WK, F1 Z19DTH 71000001 - F40WR 3,55 F5 Y30DT F40WR 3,55 EL, F2 Z20NET F40CR 3,91 ML, E8   Odnośnik do komentarza https://forum.samnaprawiam.com/topic/218-skrzynie-bieg%C3%B3w-dane-techniczne-manualne-fwd-bigblok/ Udostępnij na innych stronach Więcej opcji udostępniania...
